riggler
Hi all,
One of my LA3A's is exhibiting a no compression symptom. When the unit should be compressing, the meter lamp voltage sags instead, and no compression happens.
I thought it could have been the T4 autotransformer but ruled that out now. It's a problem on my T4B in that unit. Pins 2 & 3 are reading a dead short. I opened the T4B and lo and behold the EL panel is there, which matches the schematic.
So at this point I was confident my problem was in the T4B so I swapped the bad T4B for my other known good T4b. Unit compressed normally.
Am I missing something, or do I just need a new EL panel? I found them here:
http://www.groupdiy.com/index.php?topic=44568.0
