link to a pic of the original NYD psu:
http://i261.photobucket.com/albums/ii49/aaronmoore82/NYDpsu_p01.jpg
the link should work, but if not, go to the NYD one-bottle thread, and use the forum search engine for "NYD PSU". I built my pair with this PSU (some values changed for feeding 2), and had some hum. moving layout around fixed most of it, but when I crack the chassis next time, I'm going to try a rebuild with more filtering. However, this PSU works fine, and the hum is really only evident at highest gain settings.
Re: input tx - cinemag is great... any reason that you're using the CMMI 7 instead of the CMMI 10? Strikes me that the higher step up should give some free gain, which could be handy if you decide to add an output tx.
Re: output tx - I used one (a gapped carnhill 9600:600 from audiomaintenance - I like it). The original NYD build didn't. The result of having one is less overall gain, but you can plug your one-bottle into whatever without reservations. Also, colouration can be fun. I think that max gain with an output tx was around 36db. Despite what I thought at the time, that's hasn't been an issue.
Re: reading - do lots of it. Read the NEETS stuff, read RDH, and most importantly, read up on how to safely work on tube gear. I've done a couple of tube builds, and I still go over safe working habits every time I think about opening anything. 300 VDC = no second chances.
Also, it's probably worth it to re-read the original one-bottle thread through. It meanders, but there's a lot of good info in there, and I'm pretty sure that eventually there's a revised schem that has an output tx, a DI point, and some different (optimized) parts values. A lot of it is stuff that many folks on here could (and did) figure out themselves, but I was definitely happy to have it on paper in front of me.
