anyone able to mail me a copy of digitest for my ailing mix+ rig ?
Rob Flinn
Between Sussex, UK & Aude, France.
As it says in the title.  I need to test some cards that I'm selling.
I've tried all 3 versions for OS9 on the avid site, but none of them seem to actually recognize that there are any cards in the system at all.  Despite the fact that I can get all 24 channels to playback
Did you get one to work Rob ?
Took me long time to get a MIX+ system that was stable and reliable.
There were a batch of cards they made that had bad solder joints.
Still use my system.
I tried all the versions at avid for OS9 with no luck.  The main reason that I wanted to check the cards is that I'm selling the rig & wanted to have some peace of mind that they worked.  They seemed to work ok when I fired it up, after I reseated the farm card, but I've never been able to get digitest to run, since I got the rig, which has always seemed to work.
Martin I switched to a native PT10 system on a hackintosh with an RME raydat card, using a tascam HD recorder for converters.  It is by far the best system I've had here & I'm really pleased with it.  All running through the MCI.  Have you decomissioned you 600 yet ?
