Seeker
Hey guys, I've got a digi 192 with a channel that will not calibrate. When running calibration for -14db the input of channel 3 will not budge above -18.6. I've tried both A and B trims with the same results... I've cleaned connections, etc... sending something to input 3 under normal conditions gives extremely low signal. Does any one have any advice, other that just sending it to digi (before they stop servicing these)?
Thank you in advance...
Jason
p.s. apologies if this is not the appropriate place to ask about this...
Jason
