skal1
Ok lads ,so i been play with this thing for a while now and i can not for the life of me work out were i am going wrong.
song mix -6db so live say. Mst Chain linear eq o/p level according to the peak meter is -8.4 at the highest peak ,then we go into the opto comp ,i set
the input gain to 6 ratio 1.53.1 ,attack 41, release 5000ms , compression knob at 6.5 and the gr is about half way between 0 db and 1db the out pot
is to 0.0db and the peak meter reads -3db.
Ok everything sound fine here until i switch in the brickwall limiter input pot at 13.5 db gr -8 which is bouncing along with the track very nicely,
Attack 0.05ms and release 0.10ms so heres the deal the snap on the snare is starting to sound like a shaker .RMS 9.1 db Perceived loudness about db
10 db , so i back of the input on the brick wall limiter to 9.1db and that so better now but the RMS and Perceived loudness are way down what am i
doing wrong ? , should i eq the snare down a bit , add a gain stage ? ?.
Any help with this would be nice i can send you the clip if you like with the project preset...
skal1
skal1
