usekgb
Can I just tell everyone how much I hate working on Soundcarft K2's? In order to pull channel 24, you have to remove the bottom panel, ribbon cable, mute group connectors on the entire left side of the mixer, all the pot caps, all the nuts, the fader, and a couple more screws! what a PITA!!!!! This is all due to the fused resistor on the positive rail somehow physically shorting out with +48. How the hell did that happen? Digikey doesn't sell 1/4W 10R fused resistors either. To add insult to injury, the ELCO connector is burned, as well as the +48V trace on the PCB. I think I found a replacement for the ELCO from 3M, but the fused resistors are becoming a problem.
If this isn't bad enough, this mixer has to be operational ASAP. It's in a very busy live room, and can't run 2 channels short for very long. Whew. There's my rant for the night.
Zach
Zach
