Leslie West
- Joined
- Dec 16, 2004
- Messages
- 101
1. i am searching for a simple buffer, based on a 5534 or similar. I need to distribute an balanced Input signal to 3 balanced Outputs. It should be balanced in and balanced out. It should "sound" "neutral" as possible. Input Gain = Output gain of each Buffer....
2. If you can also show me in this circuit how I can make the gain different (poti) would be perfect... I mean: set the gain down individual via a Resistor citcuit or Poti at theses buffers....
3. btw. How many buffers can I "drive" from 1 input without any influences?
Is it possible to split 1 Signal into 10 with same gain and same "sound"?
I hope you can understand me, cause my English is terrible.....
Regards
leslie
Regards
leslie
