user 37518 said:Is a very simple circuit, however eventhough it makes sense to me, and ive done it "on paper" several times, for some reason im unsure on how "audio worthy" or clean will that PSU be, as opposed to using a bridge rectifier.
Seems only the transformers secondary voltage rating is in the title. A transformer (EI-core, toroidal, autotransformer, ..) has some more data.user 37518 said:The size of the trafo is in the title
is taking the other end of the bridge rectifier to the '24V supply' output. There will be a capacitor there that you haven't shown. This will give even higher output voltage but you don't need this.taking the other end of the bridge rectifier, not to earth, but to the 24V supply capacitor
pg.5 from http://www.studio21.ch/diy/neeno/ssl9k/DIY_9k_Preamp.pdfuser 37518 said:Harpo, no idea what you are talking about....
