schemo and layout pdf here>
http://www.jeangodbout.com/princeton/PRINCETON_REVERB_AA1164.pdf
cabinet blueprint here:
(what happened to the auto link shrink :
http://images.search.yahoo.com/images/view?back=http%3A%2F%2Fsearch.yahoo.com%2Fsearch%3Fei%3DUTF-8%26p%3Dprinceton%2Breveb%2Bcabinet%2Bdimensions&w=160&h=123&imgurl=www.bing.com%2Fimages%2Fsearch%3Fq%3Dprinceton%2Breveb%2Bcabinet%2Bdimensions%26id%3D41548A9B863E993A3B4E2882B3F7665E8B26A5A0&size=&name=search&rcurl=http%3A%2F%2Fwww.bing.com%2Fimages%2Fsearch%3Fq%3Dprinceton%2Breveb%2Bcabinet%2Bdimensions%26id%3D41548A9B863E993A3B4E2882B3F7665E8B26A5A0&rurl=http%3A%2F%2Fwww.bing.com%2Fimages%2Fsearch%3Fq%3Dprinceton%2Breveb%2Bcabinet%2Bdimensions%26id%3D41548A9B863E993A3B4E2882B3F7665E8B26A5A0&p=princeton+reverb+cabinet+dimensions&type=&no=1&tt=114&oid=http%3A%2F%2Fts2.mm.bing.net%2Fth%3Fid%3Di.4630293349664501%26pid%3D15.1&tit=Blackface+Princeton+Reverb+Cabinet+Plan%2FDimensions+-+The+Gear+Page&sigr=13i05do4n&sigi=13bp7ho17&sigb=12cu4rnvb&fr=yfp-t-701
this is my favorite Fender amp, it used to be the deluxe reverb which is the same amp with 2 extra inputs, higher plate voltage and a 12 inch speaker, but this was the first amp i used at a house party back in 64 so we are strolling back to the pediatric period as opposed to the geriatric period,
86 degrees is the baffle angle, tangent of 86 degrees is about 1 inch and change for this amp in case you have no calculator or edukation in trig,
using white board, for the sides, top and bottom, because i can get a 1 foot by 12 footer for 10 bucks, jus sayin... the same pine board was 24 bucks,
i ask the guy what is white board and he says "oh, just about any wood that's white," ??? ???
i say " kind of like chicken mcnuggets?"
and he says "yes, exactly like chicken mcnuggets only different,"
so he says it could be pine, and when i saw it, it smells like pine, i dropped boards on the concrete floor to find the plank with the best sound, security showed up and told me they were gonna call the looney wagon because i was scaring the other customers before halloween,
3/4 pine actual, 1/4 inch back boards, 1/2 inch ply for baffle,
supports are 3/4 inch sq, using oak for flatness, don't want to warp the speaker with a bent baffle,
