1176 Rev G Input Pot Wiring
lucstm
New member
Hi, I'm nearly done putting together my first 1176 Rev G but I can't seem to find accurate information or hi-res photo to find out how to connect the input pot.
Can anyone help?
Can you specify what board are you using?
Anyway... look at the attached picture (it is a rev. H/J mnats' board). You can have two cases:
1) you have an electronically debalanced input (with IC) -> simply connect pin 1,2,3 on the board to pin 1,2,3 of the input pot
2) you're using an input transformer -> connect pin 1* on the pcb to the pot's pin 1 (connect pin 2 and 3 as in the first case)
Hope this is helpful!
Also check my page (signature)!
Many thanks for the info. There's sound coming in and out!
Now I went onto the calibration procedure but the Q Bias pot doesn't change the signal level. Any idea? Thanks
