So getting closer to dialling in this compressor.
I've had to tweak a lot of stuff to suit my needs. First up, some clarification on some of my previous comments regarding the lineage of this guy.
Reviewing the info I have, it seems that 'in the beginning' was the revered Joe Meeks.
Then came the diy Weak Joe compressor (originated by ?)
- sidechain key in and out patch points
- hardwired 3dB/octave HPF
- single envelope generator path
- adjustable Attack and Release controls
- adjustable Ratio control
- no 'April resistor' ie. dry signal summing into the output makeup amp and therefore max GR > 14dB
After which, the diy What compressor V1.0 (David B Thomas)
- no sidechain key in and out patch points
- dual envelope generator path
- fixed Attack and Release
- no Ratio control
- 27K4 'April resistor' ie. dry signal summing into the output makeup amp and therefore max GR = 14dB
Then, the diy What compressor V2.0 (Fabio Bauman)
- switch modifiable 3dB/octave HPF
- option for single or dual envelope generator path
- option for fixed or adjustable Attack and Release controls
- option for fixed or adjustable Ratio control
- option for 27K4 April resistor' ie. dry signal summing into the output makeup amp and therefore max GR can be set for 14dB or greater
- option for Blend control for varying the April resistor and therefore the Max GR can be varied
To which I have added transformer i/o 1:1 all round, relay bypass, GR metering and some more modifications of various operating parameters.
I'll describe basically what I've modified, referring to the schematic rev 2 I posted of the What comp earlier.
- the sidechain hpf switch needs to have some resistance added in series with it. If you short out the switch contacts, shorting the filter stack, the gain of the sidechain goes thru the roof. So, some resistance in series is needed. I think 5K or so but I'm still messing here.
- threshhold is too bunched up in a tiny part of the threshold pot. I have reduced the gain of the threshold amp U2B by increasing the size of R9 from 2k2 to 10K. Also changed 10K log threshhold pot to a linear
The reason this is happening seems to be the current gain of the transistor Q1 bc559 used is quite a bit higher than the original bc327 and so the sidechain amp gains, as is, make the sidechain way too sensitive.
- bias control is not adjustable down sufficiently. Changed R21 to 1K from 4K64 so that the threshhold of compression can be reduced to around -45dBu, down from approx -20dBu or so
- Release control too long. Changed Release pot from 1M log to 250K log to make max release time around 1s or so.
- changed April resistor/Blend option to be 23K in series with 250K linear pot. This ensures that when Blend pot is at minimum (least Dry signal mixed into output), and Threshhold is set for no GR, overall gain at minimum makeup is unity And then, when Threshhold is set for max GR, the GR is approx -30dB (for a -10dBu input signal)
ie. ensures that when Blend is set for min dry signal mix, you can get a decent amount of max GR
- increased the makeup gain to 35dB up from approx 10dB to cater for much increased GR available with Blend control
Changed Gain pot to 500K log from 10K log
- changed min gain setting to provide unity gain when no GR. R28 to 7K7 from 5K49
- changed output dc blocking cap from 33uF to 470uF to ensure flat response to 20Hz. Also removed the current limiting resistor R29 which is not necessary with transformer coupling
Now I have lots of control - not sure if the Ratio control does anything more than the Blend or even the Threshhold
ie. just scales the amount GR amount up or down. Don't yet see any slope changes with the Ratio
I can get unity gain with no GR, max GR of around 35dB and the Blend takes that down to around 14dB by mixing in the dry signal.
Release control is now useful range instead of 5+s max
Threshhold control has some decent range on it instead of being like an on/off switch
Useful amount of makeup gain available
Blend works well
Filter defeat works
So yes - a lot of effort. Only recommended if you like to tweak alot (Sir Tweakalot)
But the unit is very useful now :
- frequency response +/- 2 dB 20-20Khz
- quiet noise wise - 35dB of makeup leaves me with a noise floor of around 75dBu which is pretty good
- lots of controllable GR with Blend restoring some transient in the case of heavy handed GR (my fav kind
Not quite finished but close.
