MC 77 First Build
djspinback69
New member
Hi All,
I have a purple audio MC77 kit that i got back in 2007, I've finally started putting it together. i've had a search around and can't find too much info on how it all goes together. i've got the schematic from the manual, i've managed to put most of it together. I could do with a little help on a few bits, a few good pics of the inside of a finished one would probably go a long way to getting it finished.
btw great forum, thanks in advance for any help
i don't know of any build type threads for the MC77.  it was meant as a no support kit so you'll need to research this yourself.  a good place to start would be an 1176 Rev.D build thread since it is the same circuit (mostly).  the schematic should be all you need to build it.  calibration is the same as the 1176 Rev.D
best of luck to you!
