emrr said:I just want to add that lately, there are so many inexpensive off-the-shelf low current 48VDC switcher modules, it hardly makes sense to build a 48V PSU anymore. There are dozens available from Mouser in the $15-30 range these days.
letterbeacon said:Ian sells a PCB, or you could just stripboard his circuit: http://www.groupdiy.com/index.php?topic=42745.0
gyraf said:+1 for a stripboard.
If you have some 12-15V AC available already, you could copy&paste the G9 phantom power part (based on a voltage tripler).
emrr said:10x less than the entire G9 at the XLR, or before the individual channel filters? And after the effects of common mode rejection on those perfectly balanced 6K8's? Let's be sure we are not apples to oranges here. I see absolutely none of the 500 rack manufacturers list PSU noise #s.
