500 RACK / EQ ONE , MICPRE ONE, MID-SIDE ONE by Total Audio Control
Status
Not open for further replies.
sahib
Glasgow - UK
Total Audio Control 500 SERIES RACKS
500 series racks with comprehensive signal splitting and routing facilities. Now available in 11, 6, 3 and 1 slot versions.
All versions are GDIY 51X, API and Radial compatible.
For detailed information please see;
http://groupdiy.com/index.php?topic=57588.msg733908#msg733908
https://groupdiy.com/index.php?topic=64358.0
11 SLOT BASIC
(Please note that the SubD25 connectors are optional.)
Kit includes;
Metalwork
Backplane PCB
Status LED PCB + LEDs + Ribbon Cable Assembly
Card Edge Connectors
Neutrik Male XLRs
Neutrik Female XLRs
Screws, nuts, wshers.
22 x 4-40 Module Mounting Screws
7 PIN DC Power Connector Set (Chassis Plug and Cable Socket)
Price GBP 255.00
11 SLOT ADVANCE
For the advance version each slot is upgraded with I/O UPGRADE kit depending on your requirements. For example, if you wish to upgrade only three slots to be upgraded then you need only three I/O Upgrade kit. If you wish to upgrade 11 slots then you need 11 Upgrade kit. However, for 11 upgrade kit you only pay for 10, and the 11th slot upgrade is free).
I/O UPGRADE
Kit includes;
3 x TRS jack socket
3 x DPDT toggle switch
1 x SPDT toggle switch
1 x Dual row 2X7 pin header
1 x Dual row 5 x 7 pin header
10 x Jumper
Price GBP 15.00 (per slot)
SUB D25 CONNECTOR ASSEMBLY
Complete with fitted ribbon and PCB transition header.
GBP 12.00 For 2 connectors as a set.
BALANCING CARD KIT
Including all the components.
GBP 35.00.
6 SLOT BASIC
Kit includes;
Metalwork
Backplane PCB
Neutrik Male XLRs
Neutrik Female XLRs
Hardware
14 x 4-40 Module Mounting Screws
7 pin power connector set (chassis plug + cable socket)
Blanking plugs
Price GBP 160.00
ADVANCE UPGRADE
SLOT I/O UPGRADE
Kit includes;
3 x TRS jack socket
10 x Jumper
GBP 15.00 PER SLOT.
GBP 15.00 For 2 connectors as a set.
BALANCING CARD KIT
GBP 35.00.
RACK MOUNTING BRACKETS FOR 6 SLOT
GBP 30.00
3 SLOT BASIC
Kit includes;
Metalwork
Backplane PCB
Neutrik Male XLRs
Neutrik Female XLRs
Hardware
8 x 4-40 Module Mounting Screws
7 Pin Power Connector Set ( chassis plug + cable socket)
Blanking plugs
Price GBP 130.00
ADVANCE UPGRADE
I/O UPGRADE
Kit includes;
3 x TRS jack socket
10 x Jumper
GBP 15.00 PER SLOT.
BALANCING CARD KIT
GBP 35.00.
MICPRE ONE
MICPRE ONE is similar in topology to the transformerless design Graham used on the Amek M2500 mixing console and the original Angela console of 1982.....
Further information with assembly manual and bill of materials can be downloaded from;
http://www.totalaudiocontrol.com/pr/show/2
Download assembly manual from the below link;
http://www.totalaudiocontrol.com/docs/MICPRE-ONE-MANUAL-3766.pdf
Link to GroupDIY thread;
http://www.groupdiy.com/index.php?topic=52443.0
The kit comes complete with all the components and a comprehensive assembly manual with detailed photographic illustration of each assembly sequence. However, as well as having a support thread here, unlimited e-mail support is also available.
Available in Black and Chrome versions.
The price is GBP 235.00
MICPRE TWO
MICPRE TWO follows the topology of the transformerless microphone preamplifier employed on the Amek Rembrandt console, with the use of dual ganged potentiometer arrangement to provide greater linearity of the gain control, compared with the use of a single ganged potentiometer.
Further information with assembly manual and bill of materials can be downloaded from; MICPRE TWO
Available in Black and Classic look versions.
The price is GBP 185.00
COMPRESSOR ONE ONE
COMPRESSOR ONE is an outstanding VCA compressor with multi-channel operation capability and user configurable sidechain filters.
http://www.totalaudiocontrol.com/pr/show/18
The price is GBP 275.00
EQ ONE
EQ ONE follows the topology of the four band parametric equaliser that Graham first used in the Amek M3000 mixing console in 1979. This was later adapted for use in M1000 and M2500 consoles and formed the basis of the equaliser design in many other Amek and Total Audio Concepts consoles....
Further information with assembly manual and bill of materials can be downloaded from MICPRE TWO
http://www.robotica.co.uk/tac/EQ_ONE_MANUAL.pdf
http://www.groupdiy.com/index.php?topic=52444.0
The price is GBP 285.00
MID-SIDE ONE
Further information with photographs on the below link;
http://groupdiy.com/index.php?topic=62527.0
MID-SIDE ONE is a very versatile M/S encoder and decoder with inserts.
http://www.totalaudiocontrol.com/pr/show/15
http://www.robotica.co.uk/tac/MID_SIDE_ONE_MANUAL.pdf
Price GBP 285.00
INSERT ONE Kit
INSERT ONE is a single width module specifically designed for providing insert points for MID-SIDE ONE when it is used on 500 series racks that do not have insert points.
INSERT ONE comes in two versions.
MID-SIDE ONE version includes the BALANCING CARD. GBP 120.00
STAND-ALONE version does not include the BALANCING CARD. GBP 95.00
For detailed info INSERT ONE by Total Audio Control
MODULE EXTENDER Kit
Complete with the ribbon cable (supplied pre-assembled), PCBs, card edge connector and test points as shown in the below image.
GBP 20.00
CMRR/SYMMETRY TRIMMING JIG. Half Kit
Half kit includes the PCBs, ribbon cables (supplied pre-assembled), card edge connector, box headers and jack connectors, as shown in the below image.
GBP 40.00
User and assembly manual with good amount of info on CMRR and SYMMETRY. Jig schematic is also included.
http://www.robotica.co.uk/tac/CMRR_TRIMMING_JIG_MANUAL_V2.pdf
CMRR/SYMMETRY TRIMMING JIG. Full Kit
Full kit includes the CMRR/SYMMETRY CARD, MODULE EXTENDER and all the components as shown in the below image.
(Ribbon cables are supplied pre-assembled.)
GBP 65.00
http://www.robotica.co.uk/tac/CMRR_TRIMMING_JIG_MANUAL_V3.pdf
PURCHASING
UK customers:
20% VAT will be applied.
EC and Rest of the World customers:
No VAT is applied.
Prices are exclusive of shipping and paypal fees.
However in larger orders bank charges often work out greatly cheaper than the paypal fee. Therefore I will be stating both options in your payment schedule.
Contact:
By e-mail to [email protected]
Beautiful work, Sahib!
I really must get into 500 stuff, starting to feel like I am missing out on some great projects.
I finished the EQ a couple of weeks ago, and it really kick asses!!!, clear & muscular sound, highly recommended fellows.
Congrats!
Interesting,because I thought they're not for sale yet........
How did you do that?
Just curious,
Udo.
Two new babies.....and guess what:They're twins,horray!!!
(I think I will name them "Angela" ;D ;D ;D)
Here's the pic,
Udo.
Here's the pic,
Udo.
Congrats Udo,
Botsf Dan,
Geile Teile !
i am jealous...i have to finish to many other projects and make one more 511 rack with new powerstation..i will end with the usual 2 more 511 racks with dual power i think  :-X ;)
wait..did not get i the last two from sahib also 8)
GAS
axel
Excellent Udo. Noticed the 4-40 shortage but some on their way out to you.
Hey Axel, one can never have enough racks.  8)
hi all,
I recently built the Preamp One, and the EQ One!!
Got to say excellent work!! great Kit, great service, awsome hardware.
No time for posting in the build thread right now but you can read my expirience at www.Eli-Audio.com
Status
