Ok, replacing the caps looks easy enough:
http://www.groupdiy.com/index.php?topic=5156.0
And grinding out the gill slots seems easy enough, although there is some debate over if you should
remove one rib, or two, or all three.
But modifying the capsule is a bit confusing here:
http://www.audioimprov.com/AudioImprov/Mics/Entries/2012/12/5_Modifying_the_MXL_991.html
It's not very clear what I need to do with the capsule. From what I understand, the clamp that holds
the mesh should be left out upon assembly????
Does anyone have links to better instructions on this?
