Crown PZM Power Supply Troubles
Travis1000
Nashville, TN
Hi all, I recently acquired a Crown PZM mic missing the transformer that converts 48V to 18V. I found the attached schematic online and after consulting David at Cinemag, I purchased a CMO-2.65/200CT. After following the schematic and building the circuit I don't get 18V! Is this schematic missing elements? Should I have gotten a different transformer? Any guidance would be greatly appreciated.
http://cinemag.biz/output/output.php
Where?
> I don't get 18V!
What DO you get?
I suspect the mike must be connected.
I recall there were two ways Crown PZMs were wired.
Thanks for your quick reply PRR! I also appreciate your encouragement to provide the whole picture!
The schematic I found was part of a .pdf document I believe was put together by Crown some years ago to supply info on there many discontinued PZM mics. While the link is dead on their site, I found it here: http://docsfiles.com/pdf_discontinued_pzms.html
As far as what voltage I am getting, none. I can measure 48V coming into the primary side of the transformer and ground, but nothing on the off of the connections label B+ and Ground.
Here is where I can thicken the plot. I have another PZM that is a complete set. It has a PX-18 Power supply which is the same as the PX-T except it can also take two 9v and supply power. It can also receive Phantom and drop it down to 18v. When I connect phantom to it, I get can get 18v without the mic connected. My conclusion is that with this type of supply the mic doesn't need to be connected.
Where?
The schematic is authoritative but baffling.
One thing I dimmly recall: some Crown PZMs, the mike-to-box cable WAS NOT GROUNDED. If you grounded it, you shorted-out DC power.
Here is _my_ best-guess reconstruction of Crown's drawing. The voltages may vary quite a bit. But there should be voltages *like* this at the places shown. Zero anywhere except _XLR_ pin 1 is a clue that something is shorted.
