zamproject
- Joined
- May 11, 2010
- Messages
- 1,503
Hello
I'm prototyping a comp/lim based around MSC (modulard-sub-card eurocard) Studer VCA
VCA schematic available here (1.914.528)
ftp.studer.ch/Public/Products/Miscellaneous/Analog_Audio_System_Components/Manuals/Single_Components/1.914.518-528.pdf]ftp://ftp.studer.ch/Public/Products/Miscellaneous/Analog_Audio_System_Components/Manuals/Single_Components/1.914.518-528.pdf]ftp://ftp.studer.ch/Public/Products/Miscellaneous/Analog_Audio_System_Components/Manuals/Single_Components/1.914.518-528.pdf]ftp.studer.ch/Public/Products/Miscellaneous/Analog_Audio_System_Components/Manuals/Single_Components/1.914.518-528.pdf]ftp://ftp.studer.ch/Public/Products/Miscellaneous/Analog_Audio_System_Components/Manuals/Single_Components/1.914.518-528.pdf
I build the "Limiter voltage processor" used to drive the VCA according to this schematic:
it's a basic 20:1, 1ms attack and programme dependant "auto release" designed to work with the VCA.
"input" is audio post VCA and "out" go to the VCA control voltage input
My idea is to modify the "voltage processor" to have more control.
I perform lot of test.
-right now i manage the threshold with a pot in place of the trim R6. Work fine
-I manage the release time with a 6 way switch, changing the R9,10,11/C2,3,4 network (i understand this is the auto release).
1 pos is the actual network, and other five position are different single R/C (fixed time). Work fine too
-ratio is set by changing R17, remplaced by voltage divider (resistor network on a 4 way selector), with output taped here. Work fine but need better adjustment
-NOW my problem, the attack time.
My understanding is, the attack time is set by R12-C5 and define the time needed to open Q3 (rectifier, peak detector and log amp send -15v instantaneously) DC go to output and also load R9,10,11/C2,3,4 (and will discharge "as slow as release time" when Q3 are close)
I change R12 with different resistor in a rotary switch, but it do not really work
I have no other idea/option right now to manage the attack time, what i do look more like a delay in Q3 opening, but the attack stay fast.
I am missing something?
any suggestions?
Zam
any suggestions?
Zam
