Should I build the M49b or c version?
Winetree
Cucamonga, California
While I'm waiting for the pair of M49 bodies, I'm going to start populating the mic's P.S.B.s.
I have Poctop's round boards. I can't decide which version to build the "B" or "C".
I figure other people haven't built these yet, but any suggestions?
I do have a real Neumann M-49, serial number in the low 700s, so I assume it a "B" version.
Over the years, I'd only used it for vocals, but because of Power supply problems, it's sat in a safe for many years.
This pair of diy 49's would probably replace it as  vocal mics,
but then too could be used as an MS pair for acoustic instruments or even room mics, or one "b" and one "C"
What's the sound difference between the versions?
I guess, by your question, that would best determine their use.
...I don't know if you saw the documentation Brian Fox provided on the modification he did for me on one of Dany's M49b prototypes...he incorporated the biasing of the "c" type on this "b" version to get the best of both worlds (lower noise and distortion, etc)...the info, schematics and charts, as well as a short soundfile of the mic on female vocals is posted here:
http://groupdiy.com/index.php?topic=50834.180
(Yes, do check the recent info by Brian Fox and kidvybes, too.)
There's even an -a or first version.
Only the -c has self bias.
This results in slightly lower noise.
But there are also tonal differences.
I can't compare them side by side, but Dany (see build threads) found the -b was fuller/thicker sounding, especially towards the lows.
But the -c seems faster on top.
There were some samples.
Similar difference for the M269b versus M269c.
In the recent VF14 thread, o3misha wrote something about the differences between -b and -c.
He later erased most of is posts, but I had copied this bit for a quote:
With self bias you have better "attacks" at the starts of notes - because of stable anode current, but not "natural" behavior at the sustain area of long notes ( you loose "body" of U47), because of floating of operation point when signal amplitude is changing , I think. Also, there is influence of the cathode cap.  Excess cap in signal path affects on sound. Thats why M49 and M49c are different in sound for example. But, of course, self biasing method has it's own benefits: less noise, for example. Better transients are very good for recording of percussion sounds, for speach, for ambience.
You'll find similar comments on the REPforum.
I'm a singer, so I guess I'm a -b guy.
Henk
...I'm no DIY tech guy, but I suspect the capsule of choice (K47-variant, M7-variant, both of which there are a number of options) has the potential to impart more differential to the overall tonality of the mic than the differences of "b" or "c", particularly on vocals, where of some low-end gets rolled of in the mix process...just my two-cents...
I built an M49c over the winter (Beesneez K7 and Oliver's T49) but recently built a choke-filtered psu and converted it to a 'b' which I must say that I prefer, especially on vocals. I like the previous poster's quote on the sound of the bias differences.
I'm curious how Brian's compromise sounds as well, although I don't really like the sound of  the 600p cap removed.
I'd been keeping a record of quotes on this. Thanks to everybody who's contributed.
I'm leaning towards a 269c w/ k67 capsule and a pair of 49b w/ m7 capsules
Micaddict:
Of the earlier, related, samples, I very much liked the D-67 with the Neumann K67 capsule (there were two Neumann capsules tested actually and one was better or better preserved maybe than the other).
The sample of the D-269b (fixed bias) with the Peluso K67 I liked a little less (although I simply loved the D-49b with the Peluso K47).
This D-269c (self bias) with the Neumann capsule sounds great to my ears. It is somewhat brighter than the typical U67 sound and the self bias may play a part in that. Different tube and setup, too. But the esses are pretty precise (I'm sensitive to that) and the mic is in no way harsh sounding. It sort of sounds like a cross breed between a U67 and a Brauner tube microphone. The latter has a K67-family capsule too, as well as a 5840 tube. But Brauners have a more straightforward circuit, AFAIK without any negative feedback at all, let alone tricks with transformer windings.
Still, some of that velvety, musical compression I hear in U67s is still present here, albeit with a little less thick midrange character and some extra air on top. So it's not just the EF86 in the U67 causing that velvety compression. It's the nature of the U67 family of microphones. The EF86 (and fixed bias) only adds to it.
In contrast, the M49 sounds smoother, creamier.
The U/D-269c is possibly even more versatile than the U/D-67. With the added air it should be brilliant for more distant recording, too. And up close, it sounds more modern than a U67 (i.e. without EQ).
Desert island microphone?
Poctop:
Thanks For the comment Henk,  With all my experience building mics i have found that there is 2 world of difference between self biased tube circuit(c) and filament biased tube circuit (b) ,  When i built the pair of 49 b and 49c  i could see a world between the 2 ,  from what i have seen so far and all my reasearch self bias microphone will be much more airy and the register will be shifted on the air , I could hear the difference  very well just listening to the ambient noise,  the filament bias type as in a U47 per example will have much more bass response and biff to it  than a self bias version , Well noted also that filament bias microphone are very sensitive to power supply noise and that i did learned it the hard way  :),  i cannot speak generally for this as some other mic , but my comparison was between the exact same model or very very  close ( M49 b, c) and (U67c and M269b) ,  in both case that is what the difference was in both case ,  with same capsule and transformer
IMO we would have had a totally different scenario if that would be the M269C  self bias later version ,  in my case i needed somthing different and complementary to the U67 and by doing the earlier filament bias M269 (1962) i think this will be the perfect complement to the U67 ,one grabs the air and the other one the bottom but in a very nice way  :), the final application will be the judge but i cannot wait to stick the M269 in front of a piano  :) and listen.
Micaddict:
According to Klaus, the U67 and the M269b sound basically the same. The M269c is less dense with more top-end clarity. Klaus has said the difference between non-c and c versions of the M269 is bigger than the difference between the U67 and M269 non-c
Micaddict:
I wouldn't worry about it, Mike. Dany's own prototype with 5840 was as far from anemic as you could imagine, "even" with the T49 tranny.
I would go for M49b rather than M49c, though.
Henk
Klause:
The  first M49 was introduced around 1951. Though not marked as "a" this was the first series, and used the Hiller MSC2 triode tube, M7 capsule and a single-leg output transformer optimized for the MSC2.
Around 1955 the tube was changed to AC701, but aside of the supply voltages and its corresponding components, everything else inside the mic remained the same.
Around early 1959 (transition periods always make it hard to pinpoint a date with accuracy, as mics would be shipped to different clients at different times) the 'b' version was introduced. From then on the mic had a humbucking transformer with 4dB more output which also could be switched between 50 and 200 ohms output impedance. The mic received the new Mylar/Polyester K49 capsule and had a few additional circuit updates, like solderable low-end cut, wire switch for cardioid only operation, etc.
In late 1961, the serial number plate started to be punched with a small suffix "c' after the printed letter "b". When the "b" serial number plates ran out, all subsequent  M49 plates were printed only with suffix "c" (around late 1963)
Fairly soon after, all M49s were equipped with a printed circuit board instead of the earlier point-to-point wiring.
The M49b/c had as improvement a new way of biasing of the tube (self biasing) which lowered the internal noise floor of the mic's tube and reduced stray hum and noise interference from outside sources as well.
The mic was discontinued in the early 1970s, with some stragglers having been shipped through the late 1970s.
Original spare parts were shipped until quite recently.
o3misha:
