FET A460 school project build
M3D!C
Member
texas
has anyone did any work on the newer PCB from 2013? im trying to put it together but there something that arent matching up from the pictures and parts list. i do have the schematic but still a bit confused.
Well it turned out to be a typo on the pcb. I've just gotten it finished this morning and but doesn't work. I think it's wiring from the capsule.  But the wire was confusing cuz you had two white wires for the 100hz-6dB and two red wires for the 0-10dB I feel I may did something wrong
The wire colors on the actual mic do not match up to the wiring diagrams,  The wiring for the switches are the wrong and the colors for the xlr are also incorrect.  You need to refer to the schematic for the wiring.  Also there is a jumper that needs to be put between the + and - on the pcb as well.
They are close to each other on the board so just use a cut off lead and solder it in.
