buildafriend
Hi guys.
I was wondering if any of you knew where I might be able to find a transformer that outputs 3.15v for heaters along with 230V for mains. I've never seen this before since all I have ever seen is 6.3v ones or the DC setup. Oh, I should also mention that I would be using 120v primaries. Maybe I could get one with a CT on the heater winding and then use the CT as the low side and regular positive tap as the high side? but then I would lose current I think..
Basically, I'm looking for a power transformer for this:
http://www.faustone.com/pdf/Faustone_Valve_Klipper_schematic.pdf
