hellokitty
New member
- Joined
- Feb 3, 2014
- Messages
- 2
Hey there,
I can not get a drop in my meter when the ratio is set to 20:1 . However, I can get a drop when the ratio is set to 4:1. I know that you are supposed to calibrate it with the 20:1 value, so I can not understand the situation. Does anyone have any experience with this problem before? Also, when I switch ratios , if I hit 4:1 the meter pings to the max for a second, then moves back to zero.
