[BUILD] The Rude Tube IVORY ====== Official build & support thread
before i order:  how about sowter 3575
edit : sowter 8940 is very nice trx too...
I just got a pair of boards - they look great!
I was looking to order pots...
Why did you spec a linear 50k for the output control? I think an audio taper would give better control.
And could it be a larger value? I'm looking for dual pots to make a stereo unit with one set of controls, and it would be easier to get a 100k.
Lundahl US is pretty damn fast. so i went with LL5402's... just finished,
already sounding awesome  8)
thanks again  :)
oh, i wired the pots wrong way round  8) ... but i am gonna leave it like that for now...
ps: STA gonna be Sowter's tho for sure.
oh boy, i am switching to double pots, and add trimmer pot for stereo balance...
fun to twist, but so  many pots on stereo CH.
i think i will fiddle with hi/lo ratio.. and gain pot... gain pot  could do wider range !?
cant wait to take it to work  ;D
Quick question regarding the stepped lorlins and the resistor placement...in the bom step 1 isn't populated?
i am using pots...
knobs arrived, stock unit working nice:)
i added switchable 1uf to C1M. rolls of fizzy_ness nicely, when needed.
added 2k7 to output LL5402 too.
If you look at the Lorlins Sheet, there are 11 resistor values, and on the PCB there is 11 Resistors.
You can't go wrong :)
https://docs.google.com/spreadsheets/d/1pTRApcKet2ZYTQa3BgFNJeYawWr7BqK_kzjqoicdIlg/edit?usp=sharing
T.
Thanks .......was suffering brain fog  :eek: ,here's a pic of my build so far ,have the tubetown tt-t56 toroidal and a case on the way :)
chris
Looks very good. I suppose you will go for 6,3V unregulated. That's fine, but nevertheless you'll need heatsinks for B+ and for additional  voltage.  R3 on psu doesn't look like a 3 watt resistor. For HT trim you could solder in a 470 R resistor instead of the the 1k trimmer.
Bernd
Yeah just waiting on the to-220 insulators before soldering in the heatsinks :) ,will use the toroidal secondary for heater,  for R3 the marking suggest 3.75w dale 470r,Mouser part no 71-CW2B-470 .
chris
Almost finished :), tried using 6.3 unregulated for heaters there was some  50hz hum ,so decided to use the PSU ,sounds great now  8)
bernbrue said:
It´s in fact the slightly modified preamp stage & EQ of the Fender Blackface Champ. You can add a 6V6 tube and transformer and you´ve got a nice little guitar amp.
regards
Bernd
How exactly would one go about doing this, and has anyone here tried it yet?
Ralph
