Gain Reduction Meter Tracking Adjustment Problem HELP!
deejaywhite
Member
Belgium, Kontich
Hey Guys,
I have a problem with the calibration (hairball method) as follows:
Set output control for 0dBu (0.775 VAC) at the output. DONE
Set attack full CCW (off position). Set input control for +10dBu (2.44 VAC) at your output XLR. DONE
Turn the attack control ON (Fully CW) and readjust the output level control for “0dBu” if necessary.
Now lets set the meter to display this 10dBu drop.  When the attack is “off” (full CCW) and you see +10dBu at the output, set the meter to 0 by using the front panel zero adjust trimmer. FAILURE
--> When I set the attack knob back to OFF, nothing happens...
What should I do?
Many Thanks,
Jens
