L lampas Well-known member Joined Nov 12, 2008 Messages 198 Jun 16, 2014 #1 Hi, does someone know, why the capacitors in the U47 are such a high voltage rank? (0.01uF = 500V, 0.5uF 250V ...). Wouldn't be 160V enough ? Thanx.
O o3misha Well-known member Joined Nov 20, 2012 Messages 229 Jun 16, 2014 #2 С2 and C3 may be 160VDC . For C1 use high voltage cap: 400-500VDC with very good isolation and very good dissipation factor.
L lampas Well-known member Joined Nov 12, 2008 Messages 198 Jun 16, 2014 #3 o3misha said: С2 and C3 may be 160VDC . For C1 use high voltage cap: 400-500VDC with very good isolation and very good dissipation factor. Click to expand... Thanks for the answer. Would Russian PIO K40Y-9 would be OK (1000V, I have a few of them) ?
L lampas Well-known member Joined Nov 12, 2008 Messages 198 Jun 16, 2014 #5 o3misha said: No, its too bulky. Click to expand... Thank you for a directions.
