"Analog Obsession" released two free plugin!
ForthMonkey
Turkey
My plugins for free...I hope you like.
EZQ
EZQ is a uniquely powerful hybrid equalizer.It has vintage and modern EQ’s curves with Dual EQ Module.
What is “Dual EQ Module”?
All bands have two eq module to adding curve and “harmonic curve”.Drive knob will give you harmonics for
bands.When the drive is off,you will get only basic eq curves.It’s like hidden eq curve.You can get aggresive
or smooth sound.
Low and Mid bands have different boost and cut curves.
Low boost is boosting with wide peak curve and cutting 1-2 dB.
Low cut is cutting like shelf but with center freq is like bell.
Mid boost is boosting with Constant-Q.
Mid cut is cutting little bit narrow curve and fixed Q to cleaning.
High freq has same boost and cut curve with non-linear curve.
-Modeled vintage & modern equalizer plugin.
-High Pass, LF bell/shelf, MF constant-Q-bell/fixed-Q bell & HF shelf filters.
-HPF:100Hz
-Low:35-60-110-220Hz +/- 15dB
-Mid:.35-.7-1.6-3.2-4.8-7.2kHz +/-15dB
-High:10kHz +/- 15dB
BAX-VANDAL
-Famous baxandall eq without HPF&LPF.
-Stepped control-5dB-1/2dB step
-Board shelving
-8 position High and Low select
-Left/Right & Mid/Side processing
-Dual Eq Module:All bands have two eq module to adding curve and “harmonic curve”
-Only Native Win 32Bit
http://analogobsession.wordpress.com/plugins/
