MXL V69 mogami edition cuts in/out
TravisCooper
New member
just got a mxl v69 from a buddy of mine, and he had swapped the tube, for a new 12AT7, and now, it works, and sounds great, but intermittently cuts in and out, more so, it drops a bit and then back at irregular intervals..... anyone had this problem before???
thanks a bunch,
--Trav
Oddly enough I had a cable that caused an intermittent fault. I bound the cable with electrical tape, which seemed to fix the problem. (I traded the mic before I found a permanent fix.)
