Bill Wilson
- Joined
- Apr 12, 2010
- Messages
- 253
The system consists of two units, cased in mahogany cases. there are two Neotek Series III 4 band parametric equalizers with transformerless balanced microphone preamps, that feature a discrete front end. The line inputs & outputs are unbalanced; they can be upgraded to balanced, for a nominal additional charge. Phantom power supply included. The power supply is a high quality dual regulated supply, that has been refurbished.
The Neotek Parametric Equalizer provides four widely overlapping bands. The Low Mid & Hi bands are silently swtchable from peaking to shelving. Hi & Low have a Q slightly wider than one octave to 1/3 octave bandwidth. Boost & cut on all four bands are + - 15db. The advantage of the mahogany casing over racking the units is that it is easily portable & easily stored; when not in use. Schematics will be supplied. As seen in the photo there are the original patch points have been preserved.
Cost: $650.00 plus packing & shipping. Selling U.S., Canada, E.U., Australia, Japan.
