clorax hurd
Member
- Joined
- Jun 4, 2006
- Messages
- 13
I just implemented the Turbo mod to my SSL, but it doesn't seem to do what it does.
I created a test signal with same sinewave in both channels, with occasional bursts of noise in one channel only. Processed it with my turbo-modded SSL, but the burst of noise in one channel does still compress the signal even in the other channel. Tripple checked my wiring and everything already.
Should I look more for solder bridges and cold joints? (did and did not find anything). Or perhaps I just misunderstood, what Turbo mod is supposed to do? It perhaps does something even now, when i use it on music, but it's hard to AB compare (and avoid placebo effect) because turning Turbo mode on does offset the threshold (very annoying).
I attached the results of my measurement. Source test signal on top, SSL processed signal on the bottom. First part is bypass, then turbo on, then turbo off, then turbo off with adjusted threshold. That's not how the turbo-processed signal should look like, right? (or wrong?)
Please help. Thanks
Please help. Thanks
