diy-tubes.com - parts for DIY studio/guitar gear
BLACK FRIDAY sale at DIY-TUBES.COM!
Register discount coupon DIYFRI and get -20% off!
Available till the midnight 28.11.2014 (Moscow time).
Just making an order..but where do insert coupon?!!
edit: found it, but "Coupon is either invalid, expired or reached it's usage limit!"
New arrivals. Some ICs, ferrite beads for projects like SSL9k and Relay Bypass DIY Kit in stock!
DPDT with flat shaft (for Tube-tech cloners) and DPDT with short shaft. 9v battery holders, compact TRS, 4PDT footswitces and more!
Very good signal relays Omron G5V-2 12VDC  and Wah enclosures in stock!
Various heat sinks for TO220, zeners 56v for phantom PSU,  power sockets and other usefull DIY stuff will be added to catalogue soon.
Visit http://diy-tubes.com for updates.
1Gohm resistors for mic builders in stock!
MF, 10%, 0,125. Russian military production.
Sorry guys! Too much things to do. No time at all. But I'll try to keep the things in mind. Thank you for reminding!
Collet wing Elfa/Sifam style knobs (BLACK and GRAY base) available with various caps colors.
Led holders, rubber mixer knobs, and other updates.
Visit diy-tubes.com for more info.
Some new knobs in stock: Rubber Davies 1510 style knobs for knurled shafts, Skirted knobs for 1176 cloners synth builders. And Elfa/Sifam style collet knobs.
Ian, as noted in description - these are for 6mm shaft size.
Thank you for enquiry!
Ian,  people are more receptive to information on pictures and icons. :)
I apologize for the extra drawing info, I will try to find some time to  edit the drawing. Thank you for your note.
