pucho812
finally got it all working and in sync.
As you may know I was getting pro tools and logic to sync via MTC and the IAC buss on a mac. I was then using a thing called sound flower from cycling 74 which would allow me an internal patchbay in the mac so I could output of logic via sound flower and into pro tools all with in sync, well as much sync as mtc allows.
Sound flower comes in 2 flavors in the aggregate I/O audio midi setup in mac, 2 channel and 64 channel.
Anyway had a problem where using the pro tools aggregate I/O and sound flower 64 channel. It would cause pro tools to give an I/O error and say it needs to reboot only to boot up and give that same error.
Well I finally got it all working. I switched the pro tools playback device to be sound flower 64 channel. I then did the same for logic.
I set up pro tools to generate MTC into the iac buss, set up logic to sync to mtc and set up the same time code rates.
Now I can run pro tools and when I do that and have logic set up, it plays as well. I can then set my outs in logic and my inputs in pro tools and record them in sync. It's pretty neat.
