Newbie PSU wiring question
mica
Denmark
I have a mic PSU i have almost assembled but want to make sure the wiring is OK so i don't blow anything up before i fire it up.
Im pretty sure about the AC and powerlamp wires, but the power input (the green one goes to ground chassis) and the switches (on/off and the 110/220V switch) , no so much. Does this look correct?
(Sorry about the crude drawing)
Hmm i really need some help with this. Everything looked ok but when i fired it up the lamp wasn't working and i got smoke from the transformer and some cracking noises... Any thoughts?
Hi mica,
I made a drawing of the Apex 460 PSU for my own reference:
I looked at what I drew and compared it to your layout sketch. If I did my drawing correctly than I think the changes I have made to your sketch, as shown below, may be helpful.
If anyone notices anything that needs correction in either drawing I will appreciate being made aware of it so that I can edit the drawings appropriately.
Thank You.
Just wanted to confirm your updated wiring sketch is correct. Everything works now.. Thanks!
/Michael
