gentlevoice1
Hi groupdiy'ers,
I'm considering a somewhat different ribbon microphone which looks like the image attached to this post. Hope it's clear what the idea is ...
One of the thoughts in doing it in this way is that summing the input from the range of conductors will give a higher output. However, before venturing into actually buying the magnets and foil I'd appreciate if one of you who knows about the intricacies of ribbon microphones can say whether or not the signal will sum - and to what extent.
A comment to the attached imagemodel:
- Between the conductors there will be a mylar like film so that the microphone conductor+film is fully attached to the structure behind, i.e. it will be a "closed" or "vented" design à la a condenser omni microphone.
- The conductors may either be connected in parallel or in series (very low resistance or somewhat higher resistance).
??? ... would the signals in the various conductors sum or does something else happen?
Cheers & thanks for any insights you may have
Jesper
Jesper
