Hello all,
I was wondering if someone could shed some light on whether or not one needs to use a capacitor to isolate the secondary of a mic input transformer from the grid of the first stage in a tube preamp.
I've noticed on one of my preamps that I get a little more headroom if I isolate the mic input trafo from the first grid with a cap and use a 1M grid resistor to ground on the tube side of the cap. Without the cap and grid resistor, it appears that the small amount of bias current travelling through the input trafo secondary is enough to saturate the transformer a bit.
I see lots of direct coupled input transformers in tube pre designs. How does one get around the problem of having bias current flowing in the input transformer secondary?
Dean
Dean
