'Rotary Switch' Encoder
tomas1808
Montevideo, Uruguay
Hi
I am looking  for a relative encoder that behaves and feels like a rotary switch.
Must have hard detents and ideally around 30º between positions. Has to be endless, obviously.
In other words an endless '12pos switch' relative encoder... if that makes sense  ::)
Does this even exist?
edit: I guess I could modify a 2 deck 12 pos switch into a relative encoder but I am not too sure about the Make before break configurations and all that jazz.
I guess I should explain a bit more:
I am trying to build a MidiBox EQ based on a API 550B plugin. This would reflect the EQ settings on whichever channel is selected in your DAW.
(Those are LED with labels on top )
The encoder I just described would be ideal for this application because one change of position of the switch/encoder would equate to a jump to the next freq band or next gain setting, in a 1:1 fashion.
Does this make sense?
Google stepped rotary encoder.
http://proto-pic.co.uk/rotary-encoder/?gclid=CNPD9cCY4sICFdQZtAodg3oAHA
Data sheet.
https://www.sparkfun.com/datasheets/Components/TW-700198.pdf
tomas1808 said:
Thanks! Just what I needed. Has a switch too!
Is there a dual concentric version of this by chance?
Check Alpha (or Grayhill/Elma etc) web site but obtaining in small quantities might be another matter.
livingnote said:
How do you debounce a regular rotary switch?
In the same way as you do a normal one. Hardware or software. Hundreds of examples on the net.
