Deepdark
ok. But how do you determine 470K. In other words, what are the maths?
Deepdark said:ok. But how do you determine 470K. In other words, what are the maths?
Deepdark said:Ok. So it take count of the overall filter section x 10 time the impedance. I'll make some research to fin out how to calculate the entire impedance of a circuit.
Deepdark said:allright. Thanks for the clarification. Is it better to strap a resistor to ground on pin 3 of the pot or I could strap pin 3 direct to ground?
Deepdark said:By the way, this is what the design i plan using. http://diyaudioprojects.com/Technical/Tube-Power-Supplies/
If you have better source for designing tube psu, let me know.
According to the process describe on the link, finding the voltage going out the rectifier is a long process. Is there a simpler way to evaluate the voltage going out the rectifier or We always have to evaluate the voltage drop, the internal resistence and all the performance data? Also, the filtering process is more of a trying and error process. Is there a way evaluate the capacitors value? I mean, i plan making the filtering section in cascade. Maybe 3 section of resistor/caps.
Deepdark said:Damn, that's close to what I've calculate yesterday, but instead of taking 4h of reading/calculating, you resume it in a simple paragraphe hahaha. I got around 355v outside the tube, i calculate i needed 2k - 2k5 resistor and around 20uf. Thanks a lot. This confirm my values. Am i better to put a bleed resistor after the rc's? 200k?
Deepdark said:Thanks Ian. I wasn't sure if I needed an elevated heaters supply. Here is a first sketch with the results I got (and yours being close) and for the heaters elevation, tel me if I'm ok. I don'T really know how to evaluate the resistors value of the pot divider. If I need around 80v of elevation, I need to drop around 310-80 = 230v ??? so around 50K ?? and for the second one, around 17K ?? is it ok?
Deepdark said:Awesome. Thank you. I'll redraw it and repost it tomorrow. I'll probably fine with 2k resistors at 8ma.
Deepdark said:Is the XSM600:600 a good candidate for input/output?
