hoodun said:
I will have to do some searching on a psu. the 51x complicates things but I will need the 24v with latest mic pre.project.
I may be able to get what I need with a 30vac 18 0 18 torrodial and some lm337 lm317 to adjust to 16, 24 and 48? ...research time.
If you are looking for the transformer only I have the following ;
Primary : 115 + 115
Secondary 1: 0 - 17.5 -25.5 @ 1.4A
Secondary 2: 0 - 17.5 -25.5 @ 1.4A
Secondary 3: 0 - 17.5 -25.5 @ 1.4A
Secondary 4: 0 - 17.5 -25.5 @1.4A
Secondary 5: 0 - 48 @ 250mA
Primary : 115 + 115
Secondary 1: 0 - 17.5 -25.5 @ 1.9A
Secondary 2: 0 - 17.5 -25.5 @ 1.9A
Secondary 3: 0 - 17.5 -25.5 @ 1.9A
Secondary 4: 0 - 17.5 -25.5 @ 1.9A
Secondary 5: 0 - 48 @ 500mA
If you are looking for PSU boards I have many options too.
I also have a new 500 series rack in 11, 6, 3, and 1 slot versions. I am working on timber/plastic cheeks for the desktop versions but you can also do it yourself. I will be updating the link with the final production stock in Black this week.
Product description;
http://groupdiy.com/index.php?topic=57588.0
White market listing;
http://groupdiy.com/index.php?topic=52462.0
However, here is a quick image of the 3 slot. The empty slot on the right is to accommodate 2 x single width and 1 x double width modules. Alternatively you can use it for on board power supply.
