dirtyhanfri said:Finally I choosed the psu in the first post and a 30VAC transformer, it's working, but giving +55VDC output with no load, maybe I could make R7 lower in order to reduce output voltage? or how could I trimm the output voltage?
It should not do that. The output is divided by two by R6 and R7 and compared to the 24V zener. I would first check the voltage across the zener.
