buildafriend
This board is designed to do the following:
Relay switching
Phase
Phantom
Pad
PCB mount XLRs
Screw terminal headers for going to the transformers, or you can just solder into those spots obviously.
It takes its power from an external supply and also gives me a mult section to help distribute power to other places. I was wondering how you more experienced guys felt about the look of it. I'm sure all of my footprints are good so my only concern I guess would be if I made any design mistakes with the traces. What do you guys think? What would you do to improve it before submitting for fabrication?
The buss connector is intended to go to a front panel PCB with the relay switches on it.
Thanks regardless,
Relay switching
Phase
Phantom
Pad
PCB mount XLRs
Thanks regardless,
