mitsos
- Joined
- May 4, 2007
- Messages
- 2,886
A little PCB I did for all those times someone wants a direct out on an old mixer. Did one old Yamaha for a friend and used this same circuit on perfboard, which is OK for a couple of channels, but after a dozen I decided to make the PCB and simplify my life. Posted on the Black Market to sell some extras, and told buyers I would post the schematic here. Anyway, pictures worth a thousand words. Really simple circuit actually, non-inverting opamp, can be set up as a unity buffer or with some gain. Impedance balanced output, and little SMD pads if you want to connect TRS sleeve to circuit ground. I usually don't.
Schematic (sorry it's kinda blurry, I can never get eagle to export decent pics without trying ten different settings.. There are no values in anyway, so I think it's self explanatory anyway).
I usually jumper the series input resistor, but you could use those pads to put in a load R if the circuit needs one (as a makeup amp for example)
I've made a few other "utility" PCBs over time, and I'll be posting extras in the BM thread as I find them.
http://groupdiy.com/index.php?topic=59028.msg749994#msg749994
