ersatz007
New member
Hi - just finished the PSU - in the US so using 110V.
Getting 123 VAC from the wall;
110:9V transformer is working fine (gives ~10-13VAC when hooked directly to power);
220:15V transformer is working fine (when connected as 110V:15V - gives ~18VAC when hooked directly to power).
However, once connected together, only getting 74V from the primary of the 220:15V (whether tested directly from the transformer wires, or via the PCB). The tube is not powering up at all. Have tried all different combinations and two different 220:15V transformers.
Any ideas?
Any ideas?
