OEPENED WHITE MARKET!!!Discrete Solid State Gain Stage For Passive EQs
ForthMonkey
Turkey
I've ordered 10 boards.Who wants?
Fully working unit.Used in my Poorman's Pultec.You can use with any passive eq.
V2 BOARD
Original circuit
http://i26.photobucket.com/albums/c107/rascalseven/PEQ-2circuit.png
VERSION 2
I saw that Version 1 has problem with Poorman's Pultec about input impedance.So i decided to improve circuit and added well known impedance converter.I used Version 1 with interstage transformer in Poorman's Pultec.There is an option to use it with electronically impedance converter or transformer.
Circuit
https://dl.dropboxusercontent.com/u/91809016/SSGAIN%20V2/Circuit.pdf
By the way my Poorman's Pultec almost done.I'm waiting for enclosure to finish it.When it's done,i will share sound and video samples.So you can hear sound of gain stage.
I would like to hear the end result!
I've already got some PMEQP1A boards from Ian and had some ideas for make up gain, but this is really neat and looks good. I might be interested in a pair.
Thank you for your interest.For now i'm waiting for enclosure to finish it.You have to wait...But boards are good and working very well.If you want,i can send a pair.Just send PM.
Humner said:
what is the purpose of "VIA"?
Do I connect those 2 pads together?
No.Just i showed them.They're connecting bottom and top layers.Don't touch them.
By the way i'm going out of city.No internet connection.I'll be here after a week.
The card is here. Just few more questions.
R13  on impedance converter,  how adjust that or more accurately - what is the target?
R14  gain trim, 10k is right?
R10 10k trim, how to deal with that?
I have few trafos  from +-16V to 30V, are those ok?
Mika
Mika
Good to see that you got board.
It's simple Bo Hansen Fet Impedance Converter circuit.Just adjust R13 for +5V  on the FET source.
Yes,R14 is gain trim.Just find sweet spot for your eq.For Poorman's Pultec,need 20dB gain.
R10 adjusting impedance converter's working voltage.Adjust it to 9V.Cause impedance converter working with 9V.
