Deepdark Well-known member Joined May 19, 2013 Messages 1,321 Location Quebec, Canada May 21, 2015 #1 Hi guys I redraw the PSU with a SS rectifier instead of the 5Y3. I would like to know if I'm ok or this will not work. Attachments SS REC.pdf 465.7 KB · Views: 34
Deepdark Well-known member Joined May 19, 2013 Messages 1,321 Location Quebec, Canada May 21, 2015 #2 here is the tube rectifier PSU. The first filter cap is 22uf instead of 12uf. The 5Y3 data sheet recall for a first filter stage of 20uf. Then I replace the 2x 12uf after the choke with 2x 47uf. Other than that, no modifications Attachments TUBE REC.pdf 431.4 KB · Views: 13
