Hi, i have some questions.
1)Is it normal that turning up the threshold at max it turns completly the volume off? (I have no compressors doing this job)
2)I put a signal of 1 KHz at the input. I set the threshold to compress 4 db. Then i swap on until 20kHz. I noticed that it changes the compression according to the frequency in input and around 6 and 10 KHz it does not compress at all! (compression does not change if i sweep down to 20 Hz).
Maybe I made some naive mistake!
Anybody can help me?
:roll:
:roll:
