why? saves space
CJ said:why? saves space
johnheath said:I did however build a clone of the V76's first stage with the EF86
I am curious about the total gain though… I need som help here
johnheath said:The NFB is actually a copy of the original except that instead of a rotary switch with the added total resistance of 30k I just replaced it with a 30k resistor. I tried to have a 25k pot to see what would happen in the first attempt and that was also without the gain pot... nothing really happened when turning the (rotary) pot ...
Please tell me how to get the heater bias to the heater supply. It is all DC...12,6VDC and 6,3VDC
2*Pi*Freq*H = choke impedance.
You need to pick an impedance. 12AX7 is often loaded with 100K resistor, so we will aim there.
You need to pick a frequency. Pick 20Hz.
There's a way to work the formula backward. But I'm lazy and just throw numbers at it.
Pick 100 Henries.
2*Pi*20Hz*100H = 12,566 Ohms impedance.
Not big enough by a long shot.
12AX7 internal plate resistance is 60K.
50Hz may be a useful low frequency.
2*Pi*50Hz*100H = 31,426 Ohms impedance, 100H at 50Hz
Say you can find 250H.
2*Pi*50Hz*250H = 78,540 Ohms impedance, 250H at 50Hz
Some further thumb-math leads to 60K impedance, 250H, at 38Hz.
Bass response will fall-off below that point.
So in a voltage-amplifier we sure could need hundreds of Henries.
