Ampeg SB12 - Schematic Question
dawsonaudio
Long Beach, CA
I'm building an Ampeg SB12 bass amplifier and have a question about the bass input connection.  There is a 100k resistor tied to the 1/4 connector.  Is that a switching jack or is the 100k hard wired to the same point as the 120k resistor?  I've seen a switching jack symbol and this isn't what it looked like.  I've got everything else wired up, but I'm not sure about this part.
Thanks for the help here.
Nate
Yes; and it looks sorta normal to me (awful compact and simplified).
In Bass jack it makes no difference.
In Instrument jack (and nothing in Bass), it forms a 120K:220K voltage divider for ~~3:2 loss and 340K input impedance. I dunno why.
When using both jacks the signals are mixed equally.
I was wondering that too since they have the 5.6M as well, which would seem like a reasonable load for passive pickups.  I guess the simple answer is - Use the Bass input!
that 5.6 meg will not mean anything when the git/bass is plugged in as the pickup DCR, probably about 8K, will dominate the 5.6 M,
nice amp, weird output tubes, have to try those,
some newer amps use a cap in series with the grid so that the pickup DCR is nullified, interesting to see if there are any sonic differences when doing this,
