I believe it is, but if asked, you will need to be able to support that declaration with a Technical FIle.
..just the fact that there are now specific rules and regs about sooooooooooooooo many "who cares?" issues.
JAY X said:Hi!
After searching and reading a lot... Self certification, asks for a construction technical file. The hard part is making the measurements that demonstrate compliment with the directives. Those measurements seems that only can be performed at a laboratory... to test EMC radiation, PSu security , etc.. and this costs money!! ... unless there is another way...
So, in short: To place an Audio product in the market you can use the self certification way: User manual/Technical file & tests/ Declaration of conformity & CE marking.
Iskrem said:Hi,
I stumbled upon this page some time ago..
http://emctestinguk.co.uk/
Anyone have any experience with them? Too good/cheap to be true? (EMC testing from £390 + VAT)
Lars
The FCC Declaration of Conformity[1] or the FCC label or the FCC mark is a certification mark employed on electronic products manufactured or sold in the United States which certifies that the electromagnetic interference from the device is under limits approved by the Federal Communications Commission
I am not a business but I make one off mixers for people. I use CE/UL/FCC approved SMPS for heaters and a CE/UL approved transformer for the HT supply. I also use an approved IEC inlet with built in filter. Then provided you get the grounding right you should be OK. To verify this I carry out a safety check using an approved PAT tester. Ths checks ground continuity to exposed metal parts and earth leakage. I can then attach an official PAT sticker to prove it has been tested because I am more concerned for my customers safety than causing a little interference.interesting reading.
What if you put in some commercial available SMPS with CE approved stamp on it ?
I mean, if you use use quality parts like IEC mains sockets and respect the basic safety rules, what can go wrong ?
I have seen far worse commercial available equipment with and without CE labeling.
What about the boutique shops that repair 70 year old guitar amps, how do they deal with safety regulations when they hand back the invoiced equipment ?
This is all a big grey zone to me.
Basic CE 'rule' is "CE + CE does NOT equal CE". In concept the certification applies to the whole system.interesting reading.
I own my own one. Mine is made by First Stop SafetyDo you have your own PAT tester or you rent one? I wasn't aware of PAT testers. It might be a good idea to own one even for the diy stuff.
Yes. PAT stands for portable appliance test. It is two basic tests. One is leakage exactly as you describe. The other is a continuity check between mains earth and exposed metalwork.I was not familiar with the term PAT, do you know if there is a different term used commonly in North America for the same thing? I know when I was designing commercial equipment we had a final factory hi-pot test which applied a high common mode voltage and measured leakage current to verify insulation integrity. Is that basically the same thing the PAT checks?
Just add that PAT testing also includes visual/manual checks.eg product casings not damaged/cracked; power cable jackets not damaged/ nicked, mains plugs correctly fitted etc.Yes. PAT stands for portable appliance test. It is two basic tests. One is leakage exactly as you describe. The other is a continuity check between mains earth and exposed metalwork.
It is used mostly in industry to carry out an annual check on the safety of office equipment like PCs, kettles and so on.
