Royer mod with T Bone SCT800 psu
globule_655
Member
Hey everyone !
I'm building myself a new mic following the Royer mod schematic for the head amp. As I have a T Bone psu that came with a SCT800 tube mic I used as donor body for a previous project, I thought I'd use it.
Stock, it gives 200V for B+ voltage, regulated by two 100V zener diodes as well as 6V regulated by a 7806.
My first thought was to just remove one of the 100V zener and replace the 7 pin XLR (already gone for the other project anyway) with 5 pin XLR. But now I wonder about 2 things : will the zener handle the power/current on its own ? Maybe I should replace it with two 50V zener in series (same as stock but half value) ?
Second I wonder about the current capability of the psu as the CV465 tube I have has a much higher max cathode current than what the 12AX7 the psu was built for asks...
Any ideas ?
Thank you very much in advance  ;D
Ok so I went on and tested the thing. I used it on a recording session on a variety of sources so it stayed on for quite a few hours  (something like 8 hrs) without any hicups.
Save the fact I don't consider this a time long enough to be sure, I still can assume it works and won't set the studio on fire after a few minutes.
Still, I'd rather know if I'd better change something or be prepared to repair the psu and/or the mic every 3 or 4 days...
Cheers !
