electric_diaries
Are there any tips and tricks to doing this with minimum interference from the heaters to other sensitive parts of the circuit?
Most of what I have read just say’s either:
A) Don’t rout it on the PCB and just use twisted pairs of wire coming away from the board.
or
B) Use DC heaters.
I would like to try routing the AC heater lines directly onto the PCB though. My instinct is to have the two traces routed side by side, or even along the same line but different sides of the PCB. However I noticed that DRIP takes a different approach, running the traces far away form each other (see the yellow highlighted traces in attached picture) which I could also imagine would work well since nothing else really seems to run along side each heater trace.
Any advice?
or
B) Use DC heaters.
Any advice?
