DIY Modular Mixer
zamproject said:
Hi Pahstah
What an nice work !!!
"DIY" definitely step up recently with Ian/Holger tube mixer and now yours.
Looking forward to retrofit a moving fader system  ;)
Best
Zam
Zam, that would be the icing on the cake!
I'm already thinking  about a version of this mixer with a separate fader bucket for your moving faders
This forum and its member are the best!!!
Paolo
P.s. Let's not forget Gary 's Sphere
mixer's done! loaded with 8 helios 69, 2 nv 1073, 2 aphelios, and 4 capi vp28 as line input. i solved the noise problem in the summing part of the console and i've found that aux sum is has less noise than group and 2bus sum!
Hi Pierre,
there is no gap between the buckets because these are two buckets put together with screws
in this image you see the 8 channel bucket on the right but in the previous image you see that i've put the 8 channel bucket on the left.
I could have made a 16 channel mixer directly with the right length of rails but at the beginning i was going for an eight channel mixer
paolo
Paolo
Hello!
Old thread I know, but worth a bump anyways.
Beautiful build. I was wondering; if you don`t mind, why not post pcb and metalwork drawings/schematics here? I know I would appreciate it to use as starting points for designing my own modular mixer. Maybe you have .fpd and pcb files even? So much learning potential  8)
