simple active fader box
doulos35
New member
alabama
could someone please look this over for me and see if anything sticks out as in error?
the concept is a simple 8 channel fader box with db25 input for a 500 series rack offering 20 db of gain and balanced transformer output summing. this is pieces cut up from esp's active mixer pages. I'm not sure if I need another buffer for the fader or not or if the insert section has enough resistance to ground.
https://www.dropbox.com/s/wfbmgys92gw0ljs/whole%20circuit%20with%20inserts.jpg?dl=0
I had a quick look at your schematic. Comments as follows:
1. DB25 is usually balanced inputs. Your inputs are unbalanced - is that what you intended?
2. I would add a fixed resistor in series with VR1A to limit the maximum gain
3. I am not sure of the purpose of R106. It just throws away gain and worsens the S/N ratio
4. Your pan circuit only has a very small dip at the centre point. You need to increase R5 and R6 to about 10K.
5. R1 on the + input of the mix amplifier just adds noise. It might help balance bias current but for audio it should be decoupled.
6. I am not sure of the purpoase of R5 and R1 in the output amps. As configured they just throw away 10dB of gain.
IAn
For the panpots, I suggest using a linear taper, dual section pot with "pull up" resistors from the wiper to the signal input terminal on each section.
Bri
thanks for that. I made the modifications you recommended. I was piecing bits from a full mixer section from Elliott Sound Products site  and I think some of those resistors were used for other things like prefade listen and things. I thought I removed most of them but guess not. Yes for now I have the mixer unbalanced in and balanced out.
I was hoping to avoid 8 dual pots but might have to go that route.
Dual pots have the advantage that they have little insertion loss so the noise performance will be better. However, in a line level mixer, the noise floor is more likely to be determined by the S/N of the source so in most cases it will not be an issue.
